7-Bedrock
July 2, 2021
IsoDraw 7.3 Fillet
I am using IsoDraw 7.3 build M080 build 6 currently. I am working on creating a graphic and was using the "Fillet" command and all was well, then all of sudden the program stop trimming the ellipse and the line segments. I have tried exiting the program and coming back in with no luck.
Has anyone had this happen? I don't know if I might have hit a key or something. It is really puzzling that it was working fine then all of sudden stopped working correctly.
Any thoughts or suggestions are welcome.
Keith
18-Opal
July 5, 2021
Have you renamed the preferences file under the C:\Users\username\AppData\Roaming\PTC\IsoDraw\Preferences. We found that when things go sideways with Isodraw this is a good place to look as it stores the preferences.
Bryon
khoward7-BedrockAuthor
7-Bedrock
July 6, 2021
Thanks Byron.
I did have to replace that file I will check it out and make sure everything is correct in the file.
Keith
