Oct 21, 2015 12:17 PM UTC
isodraw cgm VDc Extent
Hi, I try export the cgm in WebCGM2.1 format with VDC Extent setting as Page size but export is still include  all points. What's wrong?. Thanks Jan.
bfriesen
18-Opal
Oct 21, 2015 1:53 PM UTC
Are you viewing in Editor? We had the same issue, if you want export it so editor obeys the vdc extent. In the Editor install folder you need to locate a file labeled IsoConvert.prf in the isoconvert folder. There is a setting in this file that says Use CGM VDC Extent:0, change the 0 to 1. Then save and reopen the program and try again.
Bryon
jkarlik1-VisitorAuthor
Oct 22, 2015 8:15 AM UTC
Hello, Thanks. For viewing I use IsoView or Creo Viewer. I tried it, but it is still the same.
Your advise is good but I need to set the VDC Extend in Isodraw Preferences.
How to set CGM export VDC Extent to "ON" for "Page size" ?
Thanks Jan.
bfriesen
18-Opal
Oct 22, 2015 2:05 PM UTC
In Isodraw, click on edit, then preferences, locate CGM Export. Click on advanced. We have our VDC extent set to page size.
Bryon
