Jul 6, 2012 3:02 PM UTC
Isodraw macro
Dear Friends,
I am new for Isodraw macro's. Please any one guide me, How to create Isodraw macro and .ism file.
There any software using to create .ism file?
Jul 6, 2012 3:07 PM UTC
IsoDraw macros are simply created using a text editor. If you are just starting, I'd recommend just going in and recording a macro. You can then go open the file with a text editor and get a rough feel for what the language looks like.
If you have specific questions for a macro you are attempting to create feel free to post them.
Jul 6, 2012 5:45 PM UTC
Yes, I recorded one macro, that is working good.
How can I create new macro using text editor?
Please Explain me Step by step procedure for create macro and edit...
Send print screen for create macro, It will be helpfull for understand easy. Otherwise send me any samples.
Jul 6, 2012 5:48 PM UTC
If you are trying to learn how to make macros, please read through the macro help. Depending which version of IsoDraw you're working on, go under help and you'll either see a separate selection for macros or it will just be categorized under the normal help. Various samples are included in help as well as...help.
Best way to learn is to figure out a simple task you want to do. Then work through the help to do it. Use the forum if you get stuck on a step.
arasu R wrote:
...How to create Isodraw macro and .ism file...
In main program (Arbortext IsoDraw) menu select "Macro" -> "Record macro".
