May 20, 2015 11:51 AM UTC
Isodraw Macro ignores the leading zeroes
Hi Gang,
I wrote a macro for giving the ICN numbers in the illustrations. It will ask the user some specific inputs. There is a place where it will ask for the starting and ending value numbers. User would give the starting number as 00001 and ending as 0010 (for example). After running the macro when we see the file name and the ICN number in the file, zeroes in front of the value are ignored and it is displayed as 1 and 10. Why Isodraw ignores the zeroes?.
May 29, 2015 2:51 PM UTC
Looks like there may be some other errors in your macro (Run Macro?) so I parsed out the basics to get you what you needed.
Macro ICN
  Define stval as String
  Define endval as String
  Define partno as String
  Define ata as String
  Define stng as String
  Define base as String
  Define base1 as String
  Define base2 as String
  Define base3 as String
  Define base4 as String
  Define pathI  as String
  Define extI  as String
  Define fname as String
  Define cgmname as String
  Define size as Integer
  stval =get integer "Starting Number"
  endval=get integer "Ending Number"
  partno=get String "Part No."
  ata =get String "ATA"
    while (stval <= endval)
    stng = stval
    base1= "ICN-"
      base2="-A-"
      base3="-X-B-4050G-"
      base4="-A-001-1"
      while (len(stng)<5)
        stng = '0' + stng
      end while
      base =base1+partno+base2+ata+base3+stng+base4
      message base
      stval=stval+1
   end while
End Macro
May 20, 2015 1:19 PM UTC
My guess is that the variables you are using for the ICN values are declared as numbers. What you are attempting to capture however, is not a number. Try declaring your values as strings instead.
sk-31-VisitorAuthor
May 21, 2015 12:53 AM UTC
Hi Trevor,
Thanks for the reply. Below is my code. I have to declare the variables as integers otherwise the values will not get incremented. Any help is appreciated.
Macro Something
define stval as integer
define endval as integer
stval=get integer "Starting Number"
while(stval>=endval)
Create text "some point"
stval=stval+1
end while
end macro
May 21, 2015 2:46 PM UTC
My suggestion then is to treat the field as an integer as you have. Before outputting it however you'll want to check the character length of the integer and then prefix the necessary number of zeros. You can then output that value while maintaining your integer variable for incrementing.
