Feb 16, 2014 10:34 PM UTC
IsoDraw macro issue - help!
Hey up everyone - I'm hoping someone may be able to shed some light on a couple of problems I've run into...
1. I"m trying to develop a macro that will correctly format a batch of illustrations. So far everything's going to plan, but what I thought would be the easiest bit is proving the hardest. I want to use the 'fit to page' function, but I can't record it (the function is greyed out) and I can't find any reference in the help manual to script it either. Anyone done this before? After some digging it looks like this may only be a function available in 7.3 - I have 7.2, can anyone confirm?
2. I'm also trying to select any text which is less than 7pt. I have 2 different sizes on the illustration so I can't use the 'font_size is not' function.
I've been trying to develop a macro to select the smaller sized text and then lock it using the box.top and box.bottom parameters, but it fails to select the smaller size text, just the last piece of text on the illustration. It goes like this:
Macro Select text size
# recorded with Arbortext IsoDraw 7.2
DEFINE myElem AS Element
Select IF Type is equal to "Text"
myElem = activeDoc.firstSelectedElement
IF (myElem.box.top - myElem.box.bottom is smaller than 3) THEN
myElem.locked = 1
myElem = myElem.nextSelectedElement
END IF
End Macro
Anyone have any ideas why this doesn't work? In theory it should take the top box parameter and subtract the bottom box parameter of the first selected text element and if it's less than 3 (mm I'm guessing) it should lock it and move on to the next text element. All I get is that last text element locked (after a fashion) no matter what size it is.
Thanks for any ideas you may have.
Cheers
Rob
Feb 18, 2014 6:29 PM UTC
Sorted it - after much wailing and nashing of teeth:
el = activeDoc.firstSelectedElement
WHILE (Exists (el) = true)
a = el.box.top - el.box.bottom
IF (a < 6 - true) THEN
el.fill = color_black
END IF
el = el.nextSelectedElement
END WHILE
Select none
This routine fills the smaller text with a predefined colour (color_black) which I can then use as a selection criteria in future comands.
Thanks for your keen interest Trevor
Feb 17, 2014 12:01 PM UTC
Hi Rob
I've a macro that we use to scale the drawing up to fill the page. I think the original came from Trevor Hendricks (so thanks) and I changed it to suit what we needed.
submacro Resize_to_Frame_Specify_Border NOT_IN_MENU
Define Height as Float
Define Width as Float
Define ScalePercentage as Float
Define BorderSize as Float
BorderSize = 10
#SELECT THE WHOLE DRAWING
select all
#Determines height and width of grouped art.
Height = gl_TopCoord - gl_BottomCoord
Width = gl_RightCoord - gl_LeftCoord
#Determines height and width of the Active Document Window and ratio between page size and geometry size so it knows how to work out scale percentage
define page_height as float
define page_width as float
define page_ratio as float
define geometry_ratio as float
page_height = ActiveDoc.window.pageY
page_width = ActiveDoc.window.pageX
page_ratio = page_height / page_width
geometry_ratio = height / width
if (page_ratio < geometry_ratio)
ScalePercentage = (ActiveDoc.window.pageY - bordersize) /(Height)
else
ScalePercentage = (ActiveDoc.window.pageX - bordersize) /(Width)
end if
Zoom Page
#NEXT MOVE THE DRAWING GEOMETRY TO THE CENTRE OF THE PAGE PRIOR TO SCALING IT
define geometry_centre_x as float
define geometry_centre_y as float
define page_centre_x as float
define page_centre_y as float
geometry_centre_x = (gl_leftCoord + ((gl_rightCoord - gl_leftCoord) / 2))
geometry_centre_y = (gl_BottomCoord + ((gl_TopCoord - gl_BottomCoord) / 2))
page_centre_x = (page_width / 2)
page_centre_y = (page_height / 2)
define MoveDistX as float
define MoveDistY as float
MoveDistX = (page_centre_x - geometry_centre_x)
MoveDistY = (page_centre_y - geometry_centre_y)
select all
move selection MoveDistX MoveDistY
#Scales the grouped art to proper size.
Scale Selection page_centre_x page_centre_y ScalePercentage ScalePercentage
Zoom Page
# CLEARS SELECTION
Select None
End submacro
The text bit, I just use subselect for text, or does that not do what you need?
select all
Subselect if Type is equal to 'text'
Subselect if Font_size is equal to 8
Hope this helps and I've not totally missed the point.
Feb 18, 2014 12:17 PM UTC
Tim,
Thanks for your help. I'll give the sizing macro a try. Seems a shame to go to so much code when all we really need is for 7.2 to support the 'fit elements' function as 7.3 does.
As for the text part - the problem I have is that the small text I'm trying to select does not conform to an exact size (eg. 8pt), and it is not always the same size. I have text that varies from 11.708 to 11.891. Hence I could do with a function that lets me select if text is less than 12pt, but life is not so easy. That's why I'm tring to use the element box height as a measure of the text size instead.
Thanks for trying.
Cheers
Rob
Feb 18, 2014 12:33 PM UTC
Oh yes I'm sorry I assumed there was a greater/less than option in subselect, but there isn't is there!
ptc-15246431-VisitorAuthorAnswer
END IF
END WHILE
Select none
Mar 6, 2014 4:39 PM UTC
Just a late follow up, but something to think about. I personally try to avoid visual modifications as there may be a failure or something missed. Another approach versus the color would be to apply some object info metadata. Something to keep in mind for next time. The code below is an UNTESTED modification of the accepted code.
Create object_info el
el.Info.Name = "here I am"
END IF
END WHILE
Select none
Mar 21, 2014 7:28 AM UTC
Trevor,
A late follow up to your late follow up...
That makes absolute sence, don't know why I didn't think of it myself. Thanks for taking the time to give it some thought.
Cheers
Rob
