Apr 18, 2014 5:42 PM UTC
IsoDraw Macro to Change Color for all pens
I am trying to create a macro that will search through my drawing the select all the pens and set the color to black. The pen names vary from drawing to drawing and that is were I am having difficulty. I am able to change the pen color if I know the exact name, but that is not always the case. I need the macro to seach all pens reguardless of the name and change the color.
Thanks for any help you can give me!
Apr 29, 2015 4:12 PM UTC
Probably over simplifying here, but would the following work? This sets them all to a single pen type. Would obviously lose line weight or styling.
Macro Pen4All
Select All
Set Active Pen "$ISO_THICK"
Select None
End Macro
twade1-VisitorAuthor
Apr 29, 2015 4:24 PM UTC
The problem changing them all to thick is I might have different line weights in the illustration and they would all then become the same size.
