3-Newcomer
Jul 9, 2024 11:38 AM UTC
IsoDraw Macros - change the file/drawing name
I have joined newly to this community,
we use to change the file/drawing name inside as well as outside for huge nos.of drawings in ISODRAW, could u pls help me  how can i do it with help of macros in ISODRAW.
olivierlp
Community Manager
Jul 9, 2024 1:29 PM UTC
Hi @SH_8396062
I recommend giving more details and context about the problem you have in mind. Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Olivier
3-Newcomer
Jul 10, 2024 12:46 PM UTC
FILE NAMEFILE NAMEI have iso files named as above, i want to change the names in series due to adding some files in between. so 110 became 111.....so on. this how can i do it in isodraw macro, i want to do this name/ICN changes in inside as well as outside of each file.
bfriesen
18-Opal
Jul 15, 2024 8:07 PM UTC
With Isodraw open you can batch process files in a folder specifying a macro to use, but I am not sure if it can rename the original file name of the file. We have a macro that takes the name of the file and places it in the bottom right corner of the illustration.
I hope this helps
Bryon
Macro Add_FileName
  Define h As Integer
  Define w As Integer
  w = activeDoc.window.pageX-2
  h = 2
#Message "The height is " + h
#Message "The width is " + w
#Added below command to ensure number is placed on the Illustation number layer
  ACTIVATE LAYER "Illustration Number"
Select none
  Text Align Left
  Text font 'Calibri'
  Text size 6
  Create Text w h stripext(activeDoc.name)
  Rotate selection w h 90
End Macro
Emeritus
Jul 16, 2024 9:52 AM UTC
Hello @SH_8396062,
It looks like you have a response from a community member. If it helped to solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
