bfriesen
18-Opal
Feb 22, 2016 3:10 PM UTC
Isodraw placed object: how do you center it?
I know you can highlight it and choose edit, fit elements. This will center it but it will scale it to fit the square. Is there an automatic way to center the object on the page without scaling it?
Feb 25, 2016 8:36 PM UTC
Two method that I can think of.
1) Cut the content. Center the page (End key). Paste.
     Issue: Resets any IDs that might have been assigned.
2) Macro. It looks like someone posted a copy of one I had made a while back. If you decide to use this but have problems let me know. Go to the following link and a version of the macro is included.
     Re: IsoDraw origin location. Editable?
Feb 26, 2016 10:16 PM UTC
Were you able to resolve this issue using Trevor's suggestions?
If so, then could you mark the thread as correct?
If not and you resolved it, then can you indicate how you resolved the issue?
