Nov 25, 2019 2:03 PM UTC
Isodraw Preferences file (.prf)
We are using Isodraw local and via CSDB, we are not able to update .prf file for the version in CSDB same as the one local???
Somebody have idea where i could find location of .prf for the CDBD???
Thanks a lot!!
bfriesen
18-Opal
Nov 25, 2019 2:13 PM UTC
C:\Users\USERNAME\AppData\Roaming\PTC\IsoDraw\Preferences\ for a standard user. Not sure if yours is in the same location.
Bryon
Nov 25, 2019 2:41 PM UTC
Thanks Bryon,
We are using 2 licence of Isodraw, one for creatin illustrations local (but server licence) and one to import illustration into our publication system via PTC CSDB S1000D.
For the local Isodraw your right! it is located in our C:\Users\USERNAME\AppData\Roaming\PTC\IsoDraw\Preferences
but we have issue one the one in CSDB. We are trying to update the same custumize pref in both version without result. We dont know where it is located??? that cause huge problemes or Hatching substitution and linetype in our final publication... all our illustration hiden line, doted line, leader line with dot, leader line with arrow and all our Hatching change... major issue with our custumer...
Thanks a lot!!
bfriesen
18-Opal
Nov 25, 2019 2:50 PM UTC
We have found that not having the templates installed also causes issues, they could be located here:
C:\Program Files (x86)\PTC\PTC Arbortext IsoDraw 7.3\Program\Templates
or
C:\Users\USERNAME\AppData\Roaming\PTC\IsoDraw\Templates
The templates should be in one location only, not both locations.
Bryon
