IsoDraw6 compatible with Windows 7
Hello, I currently use IsoDraw6 on my XP machine and will be switching over to a Windows 7 computer. Will IsoDraw6 work on a Windows 7 computer? If so, under what settings? If IsoDraw6 is not compatible with Windows 7, i have many files created/editted from IsoDraw6 and want to know if there are any errors/effects with using IsoDraw7 on these files? Thanks, Monica
    Hi Monica, I checked the software compatibility matrix here: http://www.ptc.com/appserver/cs/doc/refdoc.jsp It doesn't show that IsoDraw is available on Windows 7 yet. I'm not sure they'll be porting 6.0 at all. 6.0 is no longer on the Product Calendar: http://www.ptc.com/cs/product_calendar/PTC_Product_Calendar.htm If you want to go to Windows 7, you'll likely need to upgrade. If you're on active maintenance, the upgrade automatically included. I can look into your other concern, but I hope Christian Schmaehl (the PM) will chime in first. If he doesn't, feel free to contact me offline. liz.fraley@single-sourcing.com Warm regards, Liz
    Hello, I work with Isodraw 6.2 and am getting ready to do testing on Windows 7 to test compatibility. Any help\info would be greatly appreciated.
    Hi John: Unfortunately, you're in the same boat. 6.2 is off the product calendar. Liz
