Jan 26, 2017 8:51 PM UTC
Isoengine73.exe and 2K12
Good morning all,
A quick questions. Is PTC --> Arbortext IsoView 7.3 --> Isoengine73.exe  Compatible with Windows Server 2012 R2 ? (With IE11)
The application came bundled with an IETP Software. The IETP Software works fine, and I am able to see the thumbnail of the illustration alright. Yet, when I click on the Thumbnail, the illustration does not open up and the Isoview Buttons do not work.
so:Is the bundled Isoview app compatible with Server 2K12 R2?
  • Are there any tricks to make it work? For example, I have already disabled pop-up blocker in IE11, Added the relevant web page to Compatibility Mode and  to the Security Tab --> Trusted Sites (with "enable protected mode" disabled)
  • I tried "compatibility mode" on the Isoengine73.exe  using XP SP3 and others
  • All of the above to no avail
Any tips or ideas ?
Many Thanks
Mariano
Jan 27, 2017 9:22 AM UTC
Hi Mariano,
Please find "Arbortext Software Compatibility Matrices" and other Arbortext IsoView 7.3 reference documents in attachment.
Jan 29, 2017 7:28 PM UTC
Many thanks Vladimir,
Since Microsoft Server 2012 R2 is not mentioned anywhere in the Software Compatibility Matrix, I assume then that it is not supported.
best regards,
Mariano
