Isometric view Problem
Dear friends,
I have some pro-E Assembly, when i was open the assembly in Isodraw 7.1 that was not set Isometric view 30/30. How can i fit correrct view.
    For better understanding, please let us see a screenshot ...
    I have attached screen shot, See the model that was not fit in correct isometric view 30/30.
    it is shown in isometric view - it is just a little bit rotated ...
    The problem is, that the model has been saved in mounting position (I think in the construction office).
    There are two possibilities: either you rotate it until it is in the correct position. Or you ask in the construction office to save the modell in correct position.
    Thank you markus,
    I will discuss my Engineer.
