3-Newcomer
Jun 11, 2024 1:03 PM UTC
Issue with .cgm Files Converting to Raster Format in pdf after Arbotext (Styler 7.1 )
Hello team,
I use .cgm files created in IsoDraw. These graphics contain vector elements and text.
When I publish the file containing these .cgm graphics, they appear in raster format and the text becomes unsearchable.
Are there any settings I need to change to fix this?
Thanks and regards
Pavan
AlexiaAnswer
Jun 11, 2024 1:24 PM UTC
Hello Pavan,
I believe you may have raised this question twice now on the Community.
Are you using the APP or FOSI print Engine?
Have you tested using the steps recommended in a previous community thread regarding this behaviour?
I see you have stated Editor with Styler 7.1 - which maintenance release ? For Example 7.1 M???0
If you are publishing with the APP Print Engine, did you test with changing some of the graphicapptransform setting?
Please Note:
  • 7.1 is a very old release stream and may not benefit from the most recent updates and fixes.
  • FOSI and XSL-FO composition is in sustained support
    • No fixes
    • No further upgrades
    • No new releases
Regards
Alexia
Alexia15-MoonstoneAnswer
Hello Pavan,
Please Note:
    • No fixes
    • No new releases
Regards
Alexia
bfriesen
18-Opal
Jun 11, 2024 1:46 PM UTC
https://www.ptc.com/en/support/article/CS141364?source=search
https://www.ptc.com/en/support/article/CS179196?source=search
  • Corrected in Arbortext Editor 6.0 M140, 6.1 M030 & 7.0 F000 using:
set graphicapptransform=cgm,idr,idrz,iso,isoz:pdf
  • Works for direct to PDF publishing
  • The stylesheet must be using the APP Print Engine for this preference to work
Bryon
olivierlp
Community Manager
Jun 17, 2024 8:57 PM UTC
Hi @PD_11070456,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Olivier
