May 29, 2014 2:40 PM UTC
Key mapping trouble
I'm debugging some of our tools, etc. in our switchover from Arbortext v5.3 for Unix to Arbortext v6.1 M010 for Windows. We have quite a few key mappings that I was hoping would not require any changes. The problem I'm encountering is that and any key combination of ALT plus a lowercase letter, e.g., ALT+c to insert a comment, does not work in the Windows version of Arbortext. If I key ALT+c Arbortext just beeps at me and does nothing. ALT plus a non-alphanumeric key, e.g., ALT+-, works just fine. Any thoughts on what could be causing this problem?
Rick
    May 29, 2014 4:17 PM UTC
    Rick,
    I am having the same issue trying to map from the command line.
    What I see when I look at the full key mapping for Epic is there are no ALT
    commands mapped to a single letter. ALT is used either with the Control key
    or by itself with all keys except alpha keys (a-z). L
    Really strange because I don't see any restriction for this in the Epic Help
    Center topic (help 9018). I tried this with Epic 6.1 M020 and also tried it,
    without success, in Epic 5.4.
    Lynn
    May 29, 2014 4:21 PM UTC
    Hi Rick
    I suspect you won't be able to map Alt-X key codes under Windows. These are used by the operating system as accelerator keys for the menu system in the Windows GUI. Eg. Alt-F is a common shortcut to bring up the "File" menu.
    This means Arbortext cannot remap that key, as it is under the control of Windows.
    // Gareth Oakes
    // Chief Architect, GPSL
    // www.gpsl.co
    rschoen1-VisitorAuthor
    May 29, 2014 4:23 PM UTC
    Lynn,
    Thanks for backing me up. I was beginning to think that I was missing something obvious.
    Rick
    May 29, 2014 4:25 PM UTC
    Gareth,
    Shoot! I understand why this would be the case but I'm not happy about it. I guess I'll have to change those keymappings.
    Rick
