Dec 10, 2010 5:03 PM UTC
Last picked line is left selected after macro is run
I've done a few macros that ask the user to select a couple of points on a drawing and then the macro draws something based on the position of the points.
The problem is that despite adding 'select none' into the macro, a line at one of the selected points always remains selected after the macro has finished.
I've done a minimalist version below to illustrate the point.
macro test_select
message "Pick a point on your drawing"
define me as MouseEvent
define start_x as point
define start_y as point
me = Wait MouseClick
start_x = me.ptMMGrid.x
start_y = me.ptMMGrid.y
create line (start_x + 10) (start_y + 10) (start_x + 25) (start_y + 25)
select none
end macro
Theres no problem if you just pick an empty point on the drawing, but if the cursor snaps to a line or ellipse, that line or ellipse becomes selected and remains so after the macro finishes.
Is there a way to stop this?
    Dec 10, 2010 5:10 PM UTC
    A quick, untested suggestion, is to insert another select none before creating the line.
    TimSharp1-VisitorAuthor
    Dec 10, 2010 5:13 PM UTC
    Thanks Trevor
    I originally had a select none both before and after creating the line but as it didn't work, I took one of them out!
    Mar 24, 2011 5:56 AM UTC
    Hi
    macro test_select
    select none
    "write macro for selecting any text - just to divert selection"
    select none
    end macro
    This is an untested answer.
    I hope this works
    Mar 24, 2011 3:20 PM UTC
    Thanks Vaduga (or is it Nathan?) and welcome to the forums.
    I'll have a try using your suggestion of adding a bit to the macro to select again before exiting and see if it works
    Jul 1, 2011 4:56 AM UTC
    Hello Tim,
    macro test_select
    select none
    CUT
    Paste_samePosition
    Select none
    end macro
    Thanks & Regards
    Vaduga
