Layers in Preference files
I have been working with the preference files in order to have the linestyles and text styles set when a user opens Isodraw. I would like to set up layers also, but I do not see a section where that can be accomplished.
Has anyone created layers in the preference files? If so could you please share with me that portion of your ".PRF" file or point me in the correct direction where to look?
Thanks for any and all help.
Keith Howard
    I don't think you can add layer preferences to the .prf file (I maybe wrong)
    The use of a template maybe the way to go or create them on the fly with a macro
    You could adjust your pref automaticaly by using macro
    See exemple.
    Macro STD Properties
    DEFINE name AS string
    name = "Set All Properties ???"
    MESSAGE name
    # Attributes/Pens
    App.window.pageY = 279.39
    App.thickthin.upTo1 = 20
    App.thickthin.upTo2 = 40
    App.thickthin.useThickThin = false
    App.shadow.shadowWidth = 1.02
    # STD Pens
    App.pens["Thick"].width = 0.61
    App.pens["Thick"].switchPen = "Thick"
    App.pens["Medium"].width = 0.36
    App.pens["Medium"].switchPen = "Medium"
    App.pens["Thin"].width = 0.18
    App.pens["Thin"].switchPen = "Thin"
    App.pens["Center line"].screenColor = "{RGB 0 0 0}"
    App.pens["Center line"].width = 0.18
    App.pens["Center line"].shadow = "Autom. Long"
    App.pens["Center line"].switchPen = "Center line"
    # Attributes/colors
    App.colors["White"].kind = "RGB_color"
    App.colors["Black"].kind = "RGB_color"
    Add color "Blue"
    App.colors["Blue"].kind = "RGB_color"
    App.colors["Blue"].color.type = "rgbValues"
    App.colors["Blue"].color.RGB = "{RGB 0 0 255}"
    # New Pens
    Add pen "Extra Thick"
    App.pens["Extra Thick"].screenColor = "Black"
    App.pens["Extra Thick"].width = 0.81
    App.pens["Extra Thick"].style = "Solid"
    App.pens["Extra Thick"].shadow = "$ISO_NOSHADOW"
    App.pens["Extra Thick"].switchPen = "Extra Thick"
    App.pens["Extra Thick"].color.type = "colorRef"
    App.pens["Extra Thick"].color.color = "Black"
    App.pens["Extra Thick"].color.tone = 1
    # Attributes/Styles
    App.linestyles["Solid"].startMark = 1
    App.linestyles["Solid"].endMark = 1
    App.linestyles["Solid"].type = 0
    App.linestyles["Solid"].pattern[1] = 0
    App.linestyles["Center line"].startMark = 1
    App.linestyles["Center line"].endMark = 1
    App.linestyles["Center line"].type = 1
    App.linestyles["Center line"].minEndLength = 0
    App.linestyles["Center line"].pattern[1] = 6.34
    App.linestyles["Center line"].pattern[2] = 0.63
    App.linestyles["Center line"].pattern[3] = 1.27
    App.linestyles["Center line"].pattern[4] = 0.63
    App.linestyles["Center line"].pattern[5] = 0
    App.linestyles["Center line"].pattern[6] = 0
    # Attributes/shadows
    App.shadows["Autom. Long"].start = 3
    App.shadows["Autom. Long"].end = 3
    App.shadows["Autom. Long"].width = 1.18
    App.shadows["Autom. Long"].color.type = "colorRef"
    App.shadows["Autom. Long"].color.color = "White"
    App.shadows["Autom. Long"].color.tone = 1
    Text
    App.txtFormats["Normal"].font = "Arial"
    App.txtFormats["Normal"].leading = 12
    # Grid
    App.grid.showGrid = true
    App.grid.constrain = true
    App.grid.gridMagnet = true
    App.grid.showDim = true
    App.grid.elementMagnet = true
    App.grid.radius = 5
    App.showCursorInfo = false
    App.magnetFlags = 7
    # Drawing Format
    App.window.pageX = 21.58
    App.window.pageY = 27.94
    App.window.curSystem = "in"
    App.window.dimScale = 1
    # CGM Export
    App.cgm.cgmlinecap = 2
    App.cgm.cgmlinejoin = 2
    App.cgm.cgmlinecap = 1
    App.cgm.cgmlinejoin = 1
    App.cgm.profile = 18
    App.cgm.textType = 2
    App.cgm.styleHandling = 3
    App.cgm.version = 4
    End Macro
