Apr 23, 2018 8:20 PM UTC
length of a string in points APP
How can I get the length of a string in points? (not the number of letters)
Florin
Apr 26, 2018 2:50 AM UTC
You're meant to run this during formatting so it picks up the current formatting properties. I haven't tested what it does outside of formatting context, it will pickup some defaults, but you can use PIs in the text string I believe (or wrap it in a styleSave(), styleChange(), and styleRestore()).
Apr 23, 2018 10:37 PM UTC
Here are a couple of options to measure a string:
APP code: <?show $^(#"Testing")>
JS code: var l = fLength(); l.text = 'Testing'; application.alert(l.makeAbsolute());
otudor1-VisitorAuthor
Apr 24, 2018 2:48 PM UTC
Hi Gareth,
for application.alert(l.makeAbsolute()); statement I get a message of "69.5666mm" and for
application.alert("length : " + l.makeAbsolute()); statement I get a message of "695666" only.
Do you know why? and in what unit is the second message? micrometers?
Florin
Apr 25, 2018 12:14 AM UTC
The second way you're forcing to a string value, the first is returning an fLength. The second value is in APP's base measurement units known as "decimicrons". You can use these units everywhere in APP by using the "dm" unit suffix.
