Aug 24, 2017 6:13 PM UTC
Locate File to Reference dialog box
Hi I'm triying to reproduce the default behavior for the insertion or edit for the element/attribute <img src="">, get a file_picker control (that Arbortext get automatically), I know that i can modify the operation with acl and js developpements, but i would like to know how Arbortext define the entitys and attributes to display the control file chooser?, it must be a config file somewhere, I would like to profit that behavior for other file document elements ex: <pdf src="">.
Thank you
Oct 13, 2017 4:07 PM UTC
@Jaime_Lee Please move this discussion in Arbortext forum, here: https://community.ptc.com/t5/Arbortext-Questions/bd-p/Arbortext
18-Opal
Nov 21, 2017 7:18 PM UTC
Normally, you would do this in ACL code, using the insert_tag document callback. Look up the help topic for "doc_add_callback" for information on how to use document callbacks, and specifically the "insert_tag" callback, to trigger a file chooser dialog (via "file_selector()" function) for your custom elements.
--Clay
