Sep 28, 2011 2:27 PM UTC
LSAR Driven Compilatioin in Parts Catalog Manager
I have a question regarding S1000D LSAR Driven Compilation.
I'm using a maintained SNS structure for a ship:
* when I select a Doc Code from the drop down list, I select the
first entry, which has a "2 37 AAO 0 My System Name".
* I get a dialog box "Add figure 2 37?"
* Then a second dialog box "Creating DMC in linked CSDB Project:
My Project Name" but here's where it goes wrong. I don't get the SNS
manager.
* A third dialog box appears and I'm getting an error which
states "The Document code does not exist in the SNS structure."
I'm trying to figure out what this means.
Does this have anything to do with the "S" Airframe/Engine setting in
the IPPN or is there another cause? I am led to understand that "S"
means chapterized and is not Airframe/Engine specific? I figure that
chapterization has to be working because I can manually Add Figure via
the Parts Catalog Manager Menu and create a 941 Data Module via the SNS
Manager.
Greg
    Sep 29, 2011 1:03 PM UTC
    Hi Greg,
    Please open a Technical Support case. This should be working. The fact that it is not working correctly could indicate that the applications have not had the project details correctly assigned and linked. TS may ask for screen shots to help assist you with this issue.
    Susan
    Susan Fort
    Product Manager, Arbortext Business Unit, PTC
    - | (937) 743-9091
    In Reply to Greg MacKenzie:
    manager.
    Manager.
    Greg
