Macro for IsoDraw 7.3 - Position and insert a new text in a CGM
Do you know how I can find the bottom right corner position of all the elements of a CGM illustration in order to add a right alignment text just below the drawing  ?
Thank you and nice day to all
bfriesenAnswer
18-Opal
March 8, 2024
Here are copies of the macro we use. It takes the filename of the idr and places it in the bottom right corner. The second macro does that same thing only it adds a white box under the text.
Macro Add_FileName
  Define h As Integer
  Define w As Integer
  w = activeDoc.window.pageX-2
  h = 2
#Message "The height is " + h
#Message "The width is " + w
#Added below command to ensure number is placed on the Illustration number layer
  ACTIVATE LAYER "Illustration Number"
Select none
  Text Align Left
  Text font 'Calibri'
  Text size 6
  Create Text w h stripext(activeDoc.name)
  Rotate selection w h 90
End Macro
Macro Add_FileName_White_BG
Define h AS Integer
Define w AS Integer
Define el AS Element
h = 2
Select none
Text Align Left
Text font 'Calibri'
Text size 6
el = activeDoc.firstSelectedElement
el.text.backfill_color.type = "rgbValues"
el.text.backfill_color.rgb.red = 255
el.text.backfill_color.rgb.green = 255
el.text.backfill_color.rgb.blue = 255
el = el.nextSelectedElement
Select none
End Macro
bfriesen18-OpalAnswer
18-Opal
March 8, 2024
Macro Add_FileName
  Define h As Integer
  Define w As Integer
  h = 2
Select none
  Text Align Left
  Text font 'Calibri'
  Text size 6
End Macro
Define h AS Integer
Define w AS Integer
h = 2
Select none
Text Align Left
Text font 'Calibri'
Text size 6
Select none
End Macro
jsterlin12-AmethystAuthor
Thank you very much for this clear and precise explanation !
It helps me understand things better, I'm just starting with Isodraw macros...
Unfortunately this does not correspond to my data, because the illustrations that I have to process are not "full page"
I was able to get around this by selecting the elements and working relative to the equivalent rectangle
Anyway, thank you very much for your help and for this quick response!!!
Have a nice day
DEFINE nomdoc AS string
DEFINE myElem as Element
nomdoc = stripExt(activeDoc.name)
select all
Group Selection
myElem = activeDoc.firstSelectedElement
#MESSAGE myElem.box.top
#MESSAGE myElem.box.left
#MESSAGE myElem.box.bottom
#MESSAGE myElem.box.right
Select none
TEXT FONT "arial"
TEXT SIZE 6
TEXT FACE NORMAL
TEXT ALIGN RIGHT
CREATE TEXT (myElem.box.right - 1 ) (myElem.box.bottom - 10) nomdoc
