bfriesen
18-Opal
Jan 25, 2017 6:22 PM UTC
macro to export cgm to users pictures folder
What does the code need to look like? Folder location would be C:\users\username\pictures\, how does it change for each individual user as the username changes.
Macro export CGM to user pictures folder
# recorded with Arbortext IsoDraw 7.3
  app.interaction=false
  Save
  Define final2 as string
    final2="X:\Photos\" + stripext(activedoc.name) + ".jpg"
    Export final2 "JPEG"
  app.interaction=true
  Save
  Define final as string
    final="C:\users\username\pictures\" + stripext(activedoc.name) + ".cgm"
    Export final "cgm"
End Macro
Bryon
    Jan 26, 2017 6:23 PM UTC
    Check to ensure you have a C:\temp folder on your computer. It's pretty standard but...
    This is also assuming you used macro exactly. If not, please post the contents of your macro.
    Jan 25, 2017 8:41 PM UTC
    If I understand, you want the following line to vary depending on who is running the macro. Correct?
    If I'm understanding, I do not believe there is a way to capture the user name. There is a 'system' type command.
    Try this as an alternative. Hopefully the comments all make sense.
    Macro myExports
        #Define variables.
        Define JPGLocal as string
        Define CGMLocal as string
        Define fileName as string
        Define CMDLocal as string
        Define tempLocal as string
        Define tempCGM as string
        #Define cmd.exe.
        CMDLocal = "C:\WINDOWS\system32\cmd.exe"
        #Define local temp Local.
        tempLocal = "C:\temp\"
        #Turn off possible error/warning prompts during export.
        #Save file to current Local.
        Save
        #Define variable for file name
        fileName = stripext(activedoc.name)
        #Set export Local for jpg.
        JPGLocal="X:\Photos\" + fileName + ".jpg"
        #Export jpg.
            Export JPGLocal "JPEG"
            #Set temp CGM export path.
            tempCGM = tempLocal + filename + ".cgm"
            #Set final cgm Local using cmd format (%variables%).
        CGMLocal = "%userprofile%\pictures\" + stripext(activedoc.name) + ".cgm"
        #Export CGM to temporary location.
            Export tempCGM "CGM"
            #Calls a cmd window and runs a move command to move the file to the final location.
            Launch CMDLocal "/c move /Y " + tempCGM + " " + CGMLocal
            #Turns prompts on.
    End Macro
    bfriesen
    bfriesen18-OpalAuthor
    18-Opal
    Jan 26, 2017 5:04 PM UTC
    Thanks Trevor, I am getting an error log that states
    MacDon_macros.ismexport CGM to User Pictures folder
    The file '%ls' is not open. "Export tempCGM "CGM""
    Bryon
