Apr 5, 2016 10:12 AM UTC
Many languages in one topic, just one needed in pdf.
Hi, I have many paragraphs in differents languages in a same topic.
Each paragraph have xml:lang attribute like : <p xml:lang='en'>Hello World</p><p xml:lang='de'>Halo Gerrit, get's?</p><p xml:lang='fr'>Salut à tous.</p>
I want to publish this topic in pdf one time only in english and/or one time only in german and/or one time only in french.
How can I do that, just with Styler and Windows (no SIM, no PE or anything else) ?
Thanks.
Hugues
Apr 6, 2016 11:44 PM UTC
You should explore the Arbortext feature called "profiling". If you want to produce a PDF you will also need to have a print capable license, such as Arbortext Styler, Publishing Engine or Print Composer.
hfrancois1-VisitorAuthor
Apr 7, 2016 4:32 PM UTC
Thanks Gareth,
i have read profiling feature and i don't find topic about "language". Just about profil.
How can i control publishing by testing the xml:lang attribute value?
Apr 12, 2016 12:28 AM UTC
The profiling feature allows you to filter published content according to a specified "profile". So for example you can identify attributes and values that are to be used for filtering. For languages, this could work that you set a profiling value of "en", and all elements with xml:lang not "en" will be removed before publishing. This approach would allow you to produce an single-language PDF from content that is authored in multiple language variants.
Apr 11, 2016 11:47 AM UTC
Have you reviewed Arbortext Styler's translation features for gentext material? See Arbortext Editor's Help Center topic "Generated Text Overview", "Maintaining Translations of Generated Text" and "Managing Translation Units"?
