Dec 23, 2016 4:02 AM UTC
MathML with mml namespace cannot display correctly in AAPP.
My equation's mathml code has a namespace called mml, i have declare the space in the root xml tag, as "<Doc xmlns:mml="http://www.w3.org/1998/Math/MathML">", and set the libxml parser in Document Preferences, but i cannot display well. What's the reason?
Jan 3, 2017 9:25 AM UTC
You will need to adjust 3B2's own internal namespace mapping in the library tag thats loaded as well.
There might be some info on this in the documenation pdf thats gets installed with the markup libraries which i presume you are using?
If you need more hands on assistance please feel free to get in touch directly.
Regards
Chris
www.tformat.com
