Migration from Unix to PC
It has been a while since I last asked for assistance, but I'd like to
throw this out and tap into the vast range of experience I've come to
appreciated from fellow adepters.
I am just beginning to look into migrating from a Unix server
environment where about 30 authors log on from Unix workstations to
access a common Arbortext Editor installation and rehosting to a PC
based environment. I would like to continue using the client-server
model so I will have a single installation to maintain. I was wondering
if there are any big issues with this approach and recommendations on
how to approach this. We are a small operation and are only looking to
use Arbortext Editor for editing SGML document, not to publish them.
Robert Paisley, MSCS MSSE
Northrop-Grumman
Level 5 Engineer
All truths are easy to understand once they are discovered;
the point is to discover them. - Galileo Galilei (1564 - 1642)
    My understanding is that with PCs, you can maintain all the configuration files and shared folders in one single place. Each PC installs, not from a CD, but from a special setup file from that server. If I recall correctly, each time you load, it checks the server custom directory and automatically updates the distributed PCs.
    For those of us complaining about load-up speed, hear this: it allows you to configure a "compact" installation for the users.
    I have tried making the custom install and it is simple to do. We all had it installed already so I haven't actually used it...yet.
    From the Arbortext Editor Deployment Kit Guide:
    The Arbortext Editor Deployment Kit enables you to develop a customized, compact
    installation of Arbortext Editor for the Microsoft Windows platform that can be distributed
    to users through a web site, shared network folder, and so forth. This chapter covers the
    contents of the Deployment Kit and provides an overview of the process for creating a
    compact installation.
    John T. Jarrett CDT
    Senior Tech Writer, Integrated Logistics Support,Land & Armaments/Global Tactical Systems
    T832.673.2147 | M 832.363.7234 | F 832.673.2376| x1147 | -
    BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
    www.baesystems.com
