7-Bedrock
Mar 3, 2025 10:31 AM UTC
Missing linked table when exporting pdf
Linked table is missing when exporting pdf. Chapter where table is linked as excel file. Table consists with descriptions and clickable page number.
Compering to my colleague, we have the same settings, preferences, styler, but mine does not export linked tables.
This table generator that does not work was developed specifically for our company the same goes for Styler.
What could be the problem? Am I missing some additional settings?
Thank you for your help.
7-Bedrock
Mar 10, 2025 9:03 AM UTC
Hi Vivek,
Last week we found solution to our problem. After inspecting in details all installation and Arbortex preferences we found under Session that mine program had different Custom directory path. When we than changed this path to where it should be, table was made when exporting pdf. We moved Arbortext and creating right shortcut on desktop. Now everything works perfectly.
Would it be possible to delete my post? It was also invented specifically for our company…
Thank you for your support,
Br, Ana M. Sparovec
Best regards │ Lep pozdrav
Ana Marija Šparovec
Technical Documentation Consultant
Danfoss Trata d.o.o.
Danfoss Climate Solutions
www.danfoss.com
This message and any files transmitted with it may be confidential and are intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system.
Classified as Business
Emeritus
Mar 7, 2025 11:17 AM UTC
Hi @AS_12920274,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
AS_129202747-BedrockAuthorAnswer
7-Bedrock
Hi Vivek,
Br, Ana M. Sparovec
Ana Marija Šparovec
www.danfoss.com
