Jul 14, 2010 7:57 PM UTC
Modify Attributes causing program crash?
Hi everyone,
I am having a problem I hope someone can help me with...I have installed a DTD, associated a style sheet in a new document in Arbortext 5.3. When I select the introductory tag and attempt to insert an attribute I am prompted with the "Modify Atributes" tab. After selecting any of the options, I see the information populate the program, however the modify attributes popup completely freezes and I have to control alt delete. Can anyone please tell me what is happening here? I'm basically unable to do anything in the program now. Thanks very much
    Jul 27, 2010 10:19 AM UTC
    Good day, Doug.
    I have a few clarifying questions...
    Do you mean the "root" tag as the introductory tag?
    Is the issue reproducible with other (non-root/non-introductory) tags?
    What do you mean as "I see the information populate the program"?
    Is the issue reproducible with non-custom doctypes (e.g. DITA topics or Docbook)?
    What build (M???) are you using? Did you try another builds or 5.4?
    May 30, 2011 6:02 PM UTC
    I realize this was a long time ago but was it ever resolved. I just installed patch M190 for AE 5.3 and when I open the attributes window it just freezes. I have to ctrl+alt+del to get out of it.
