bfriesen
18-Opal
Nov 8, 2023 7:58 PM UTC
Multiple part numbers in a table for multiple versions of a manual
Good afternoon, we have a dilemma that we are trying to solve. We create multiple variations of parts books that need different part numbers for the same part.  Currently we manually add all the versions and profile accordingly. I would like to automate it if possible.
Example below
Book 1 has part 123
Book 2 has part 123, but needs it to show up a A12
Book 3 has part 123, but needs it to show up a X2A
Is there a way to retrieve the correct number when building the publish?
Bryon
18-Opal
Nov 8, 2023 8:09 PM UTC
Hi Bryon--
This is what the DITA keydef/keyref mechanism is for. You can have your main content with key references, where the part references use IDs (keys) that look up part number strings in a different file (the key definitions). So you would have one key definition file for each variation, and then swap them out (i.e. have a bookmap for each configuration that imports the correct keydef file) to produce the correct result.
See the help center for more info on key references: https://support.ptc.com/help/arbortext/r8.1.2.0/en/#page/editor%2Feditor_help%2Fhelp17173.html
--Clay
18-Opal
Hi Bryon--
--Clay
bfriesen
bfriesen18-OpalAuthor
18-Opal
Nov 8, 2023 8:18 PM UTC
Thanks Clay, we tried using keydefs early in our Arbortext adventure and found that we had issues with translation, so we stopped using them. This might be a good place for them because there are no words.
Bryon
