Need to trigger "OK" button in print dialogue of IsoDraw via macro
- 8 replies
- 5283 views
- Translate All
I need a macro event to trigger the "OK" from the print dialogue box. I wrote the following macro to print the viewports in a drawing, but I have to manually select the "OK" button each time the macro goes to print the active viewport. A bit of a pain since I have between 8-15 viewports per drawing when I print the .cgm drawings I produce. Attached is the code.
