New Document as Read Only
We have a custom Schema and I added it in the New Dialog window. The root element is called <document> and AT inserts the root element. Then when I try to insert the other child element of the root element AT gives the error message as this "Document as read-only". I cannot insert any more elements after document. So I did a save as and renamed it as different file. Now I could able to insert the rest of the child element.
The issue still presets - When I save the document it still says as read-only document:-( 😞
I closed the AT window and I get the prompt to save the file with "Yes" and "No" button and I clicked Yes. When I reopened the file again all I could see in <document> element. Here is the interesting thing - Now I could able to modify the document and save it with changes. Is this a typical AT behaviour or am I missing something?
Karthik
