New doubt about lists, java an ACL
Hello experts!
Today I'm having a problem with my development using Java and ACL, I'm
trying to pass an ArrayList from Java to ACL. I tried to pass it through
Acl.func() however I found that this function only allows String
parameters, I don't know how can I pass a List; I would like to know...
is this possible?! Please if anybody has any suggestion, or an alternate
implementation I would be pretty glad you could tell me.
As always I really appreciate your time, also your comments and support.
Best Regards.
Paulette Zorrilla
    Greetings,
    You should look at the functions:
    java_array_from_acl(arr, descriptor)
    This function converts the ACL array arr to a Java object and returns the Java object. The class of the Java object is specified by the descriptor.
    Help 6005, 6006
    - Dave H.
    Dave Helfinstine
