New JVM with larger capacity?
    Hi, John...
    As I understand this description, the newer version of the JVM just
    has different defaults for the memory settings. All versions of the
    JVM allow these settings to be changed on startup, generally through
    command-line options.
    For instance, "java -Xms1024m -Xmx2048m -Xss4m" would set the initial
    heap size to 1GB, the maximum heap size to 2GB and the stack size to
    4MB.
    However, since Editor or PE start the JVM for you, you need to use the
    javavmargs and/or javavmmemory options to specify your settings. I
    recall there being some issues with where these need to be set so that
    the settings are in place before the JVM is started (setting them too
    late will be ineffective), especially since newer Arbortext versions
    apparently tend to start the JVM earlier than in the past.
    Unfortunately, I can't find the details, so if this seems to be a
    problem, post back and maybe someone can shed some light.
    -Brandon 🙂
