bfriesen
18-Opal
May 14, 2013
Newbie key mapping help
Trying to map F12 to add the index marker to text, but do not know enough to see what I am doing wrong.
Here is what I got so far. Can someone shed some light for me.
function table auto_index()
$table_rows=tbl_row_count()
$column_to_process=tbl_caret_col()
while(tbl_caret_row() <= $table_rows && tbl_caret_row() > 0) {
oid_select(oid_caret(0))
copy_mark mymark
insert_tag(indexterm)
paste mymark
# insert("-")
if (goto_cell(tbl_caret_row()+1, $column_to_process) != 1)
break
map F12 auto_index();
Bryon
    18-Opal
    May 14, 2013
    Hi Bryon--
    Your code seems to have gotten munged by the email software, so it's a
    little hard to see what you've got there. However, one thing to check is
    whether you are defining your function inside a named package. If there
    is a "package" statement in the ACL file where you are defining this
    function, then you will need to include the package modifier in your map
    command. For example, if this is in a package called "table", then you
    need to use something like this:
    map F12 table::auto_index()
    Hope that helps.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
    Bryon,
    Like Clay said, your code came across pretty mangled. I copied and tried to
    see what I could do with it.
    This is what I came up with.
    function table
    auto_index()
    {$table_rows=tbl_row_count() #this counts the rows
    $column_to_process=tbl_caret_col() #this one tells it to process where the
    cusor location is
    {oid_select(oid_caret(0))copy_mark mymark
    paste mymark#
    insert("-")
    {break}}
    When I did a 'brace' comparison with Codewright, there is an unmatched set
    of braces. Fix that and see what happens.
    Lynn
    bfriesen
    bfriesen18-OpalAuthor
    18-Opal
    May 14, 2013
    Thansk for the help, I noticed after I posted it was all crazy. I have edited the original post to show what I have in my text file. The purpose of this acl is to place your cursor in the top cell of a column,press f12, it will add an indexterm element with the contents of the cell populating it. The original version that I have works, but needs to be local on everyone computer. I have switched to a .zip sma, so I can manage everything off of a network drive instead.
    If I have this acl code save locally, it can be invoked by source auto_index.acl. Iooked at other acl scripts that I have had help with and tried to map
    copy_mark mymark
    paste mymark
    # insert("-")
    break
    Thanks for the suggestion Clay do I need to add that at the begining or at the end? I am reading the acl reference but... not sure what I am reading.
    function table::auto_index() {
    copy_mark mymark
    paste mymark
