Mar 28, 2018 8:34 PM UTC
No table header text in PDF
I'm working on a document that uses the 40051 DTD.  In Arbortext, the header text for tables looks fine but when I create a PDF (File > Publish > PDF File), the table header text doesn't appear.  I tried changing the valign attribute for the header row from bottom to top and middle, but that didn't make a difference.  Also, I pasted the table code in a DITA concept topic and it published to PDF with no problem.
Bob
Mar 29, 2018 9:57 PM UTC
What formatting engine are you using?
Bobbert10-MarbleAuthor
Mar 30, 2018 12:17 PM UTC
We print to PDF in Arbortext 7.1 (File > Publish > PDF File).
Mar 30, 2018 5:47 PM UTC
If this was a FOSI stylesheet, I could help, but you have XSL stylesheets.
