Jun 14, 2016 8:49 PM UTC
Open from PDMLink
Okay I am having a little issue with a small script I am trying to create.
Here it is in a nutshell.  I need to flatten the current document, send it to a service and then open the original file again.  The first two are no problem. I am having a heck of a time opening the original book back up from PDMLink.
Here is my code thus far:
package processInteract
function createInteract(){
    local res1;
    local doc;
    local newname;
    local doc1
    doc = current_doc();
    doc1 = doc_name(current_doc());
    res1 = response("Have you saved? Running this command you will loose any non-saved changes!", "&Yes", "&No", "&Cancel");
    if(res1 == "1" ){
        doc_flatten;
        newname = "c:\\temp\\" . time();
        #message_box(newname,0x20);
        save_as $newname;
        file_close(win,0x0001);
        arg1 = newname. ".xml"
        system('java -cp \\lynms313q\codebase\InteractiveManualCreator.jar;\\lynms313q\codebase\wvs.jar;\\lynms313q\codebase com.toro.plm.pdmlink.arbortextadapter.ArbortextAdapter ' .arg1)
        view(doc1);
function view(pdmFileName){
local wcPrefix = "x-wc://file=";
local pdmLogicalId = wcPrefix . pdmFileName;
response(pdmLogicalId);
document = doc_open(pdmLogicalId);
curr_win = current_window();
doc_show(document, curr_win);
This is an alternate way that I was trying as well.  It will open the object below the parent object....
    local res1;
    local doc;
    local newname;
    local doc1
    local dobj = doc_first_dobj(current_doc());
    dobj_close(dobj);
    response("Logical Id = " . dobj_get_attr(dobj, "IO_ATTR_LOGICAL_ID"));
    response("Dynamic Dcoument Name = " . dobj_get_attr(dobj, "WC_NAME_ATTR"));
    if(res1 == "1" ){
        doc_flatten;
        save_as $newname;
    document = doc_open(dobj_get_attr(dobj, "IO_ATTR_LOGICAL_ID"));
As always any help would be greatly appreciated...
Brian
byorkAnswer
Jul 7, 2016 9:04 PM UTC
Just in case anyone wants this but here is the working code
    local res1;
    local doc;
    local newname;
    local doc1
    local logid = doc_path(current_doc());
    if(res1 == "1" ){
        doc_flatten;
        save_as $newname;
        edit "$logid"
byork17-PeridotAuthorAnswer
    local res1;
    local doc;
    local newname;
    local doc1
    if(res1 == "1" ){
        doc_flatten;
        save_as $newname;
        edit "$logid"
