May 30, 2014 5:06 PM UTC
Parenthesis around numbers
Hi All,
I'm looking for guidance on adding parenthesis around numbers using FOSI. I have the numbering in the document, but for some reason can not figure out how to add the parenthesis around the numbers.
TimPhelpsAnswer
May 31, 2014 6:54 PM UTC
Jay,
Have you tried in your <savetext> or <usetext> using the syintax
\(\,thenumber,\)\
It is described in the Arbortext Editor's help topic
Savetext construction rule and usetext source syntax.
Best regards,
Tim
TimPhelps12-AmethystAnswer
Jay,
\(\,thenumber,\)\
Best regards,
Tim
Jun 2, 2014 2:20 PM UTC
HI Tim,
Your solution worked great. Thank you for your help.
Jay
