Paullette: Look! - Coloring xml nodes
This old post provides one strategy for highlighting some of the
text/elements within Editor. Hope it gives you some good ideas.
    OMG! I will check it and test it; I had not thought of this option.
    Hello again 😃
    I have been searching more info about FOSI, however is pretty confusing for me now, If any of you know more general and basic information I will really appreciate your help, for example, I would like to know how do I implement a FOSI screen stylesheet? I have been trying with my init.acl file and the 'set stylesheet' command but I can not see any change or any difference in my documents, also I think this is because I don't know how FOSI works =( ...I mean, I don't know if when I open an existing document automatically mi stylesheet would be applied; what I'm trying to get is that when a user clicks a button, some text be highlighted in a specific color, I would like to implement this approach dinamically using ACL, please if any of you could explain me more about FOSI I would be really grateful.
    As always I really appreciatte your time, comments and support.
    Regards, Paulette Zorrilla
    naglists1-VisitorAuthor
    The simplest way is to save the FOSI with a filename that is the doctype
    name and store it in the doctype's custom doctypes' subfolder. (That's more
    of a mouthful than it should be!) For example:
    ...\mydoctype\doctypes\mydoctype\mydoctype.fos
    In this scenario, your DTD would be:
    ...\mydoctype\doctypes\mydoctype\mydoctype.dtd
    Close and reopen Editor if it was open while you did this. Also, do not
    have a mydoctype.style located in the same place. It will take precedence.
    On Wed, Apr 10, 2013 at 6:22 PM, Paulette Zorrilla <
    paulette.zorrilla@oracle.com> wrote:
    > Hello again 😃
    > grateful.
