PDF Bookmarks on PE Server
Hello All,
I have been able to get PDF bookmarks to show when using File->Compose->PDF File locally but not when I do File->Print Composed from a PE Server. Any advice would be appreciated.
In top level eic:
<att>
<specval attname="print-only" attloc="system-var" attval="#ANY">
<charsubset>
<usetext<br/>source='!<atidmd:documentmetadata source="atend"><atidmd:docview mode="bookmarks"&lt;br"/> fit="fitPage" destination="></atidmd:docview>
</atidmd:documentmetadata>!' placemnt="before"></usetext>
</charsubset>
</att>
<att>
<charsubset>
<usetext<br/>source="!<atidmd:documentmetadata>
<atidmd:docinfo>
<atidmd:entry>
<atidmd:key>Title</atidmd:key>
<atidmd:value>!,tmnocmn,!</atidmd:value>
</atidmd:entry>
</atidmd:docinfo>
<atidmd:outline><atidmd:bookmark>!,doc-title-bookmark.txt,!<atidmd:bookmark>!,main-toc-bookmark.txt,!</atidmd:bookmark><atidmd:bookmark>!,vol-bookmarks.txt,!</atidmd:bookmark></atidmd:bookmark>
</atidmd:outline>
</atidmd:documentmetadata>!" placemnt="after"></usetext>
</charsubset>
</att>
Volume titles:
<savetext textid="vol-title-bookmark.txt"&lt;br"/>conrule="!<atidmd:title>!,volstrg,!</atidmd:title>!" placemnt="after">
<savetext textid="vol-bookmarks.txt"&lt;br"/>conrule='!<atidmd:bookmark state="closed">!,vol-title-bookmark.txt,vol-toc-bookmark.txt,chapter-bookmarks.txt,!</atidmd:bookmark>!'
placemnt="after" append="1">
<savetext textid="chapter-bookmarks.txt"&lt;br"/>conrule="\" placemnt="after">
Chapter Titles:
<savetext textid="wp-bookmarks.txt" conrule="\">
<savetext textid="chapter-title-bookmark.txt"&lt;br"/>conrule="!<atidmd:title>Ch. !, modulectr,\ - \,titlelevel,imtype,!</atidmd:title>!"
placemnt="after">
<savetext textid="chapter-bookmarks.txt"&lt;br"/>conrule='!<atidmd:bookmark state="open">!,
chapter-title-bookmark.txt,wp-bookmarks.txt,!</atidmd:bookmark>!'
<savetext textid="vol-bookmarks.txt"&lt;br"/>conrule='!<atidmd:bookmark state="closed">!,vol-title-bookmark.txt,vol-toc-bookmark.txt,chapter-bookmarks.txt,!</atidmd:bookmark>!' placemnt="after" append="1">
<savetext textid="chapter-bookmarks.txt" conrule="\" placemnt="after">
WP Titles:
<savetext textid="wp-title-bookmark.txt"&lt;br"/>conrule="!<atidmd:title>WP !, wpseqno,!</atidmd:title>!" placemnt="after"><savetext<br/>textid="wp-bookmarks.txt"
wp-title-bookmark.txt,!</atidmd:bookmark>!' placemnt="after" append="1">
    Short on time, so this will be brief and just pointers to thing to look
    into and/or report back here:
    I believe Print Composed PDF Bookmark support was withdrawn. I do not
    remember with what version. You must be doing a Compose PDF. Whether you
    are using Distiller, the Acrobat server version, or PDF Direct (or Direct
    PDF ... the pdflib built into PE after a certain version) may also matter.
    Your DCF may also need to specify the right things. PDF Bookmarks require
    DIV status in the DCF, I think.
    So:
    What version of Publishing Engine?
    Acrobat/distiller/pdflib?
    What does your PDF say about the elements' DIV status?
    On Mon, Nov 25, 2013 at 2:27 PM, Caroline Leccese <
    caroline@thecodesource.net> wrote:
    > Hello All,
    > In top level eic:
    > <att>
    > <charsubset>
    > <usetext<br/>> source='!<atidmd:documentmetadata source="atend"><atidmd:docview<br/>> mode="bookmarks"
    > </charsubset>
    > </att>
    > <att>
    > <charsubset>
    > <usetext<br/>> source="!<atidmd:documentmetadata>
    > <atidmd:docinfo>
    > <atidmd:entry>
    > </atidmd:entry>
    > </atidmd:docinfo>
    > </atidmd:outline>
    > </charsubset>
    > </att>
    > Volume titles:
    > <savetext textid="vol-title-bookmark.txt"&lt;br"/>> conrule="!<atidmd:title>!,volstrg,!</atidmd:title>!" placemnt="after">
    > <savetext textid="vol-bookmarks.txt"&lt;br"/>> conrule='!<atidmd:bookmark<br/>> state="closed">!,vol-title-bookmark.txt,vol-toc-bookmark.txt,chapter-bookmarks.txt,!</atidmd:bookmark>!'
    > <savetext textid="chapter-bookmarks.txt"&lt;br"/>> conrule="\\" placemnt="after">
    > Chapter Titles:
    > <savetext textid="wp-bookmarks.txt" conrule="\\">
    > <savetext textid="chapter-title-bookmark.txt"&lt;br"/>> conrule="!<atidmd:title>Ch. !, modulectr,\ -
    > placemnt="after">
    > <savetext textid="chapter-bookmarks.txt"&lt;br"/>> conrule='!<atidmd:bookmark state="open">!,
    > <savetext textid="chapter-bookmarks.txt" conrule="\\" placemnt="after">
    > WP Titles:
    > <savetext textid="wp-title-bookmark.txt"&lt;br"/>> conrule="!<atidmd:title>WP !, wpseqno,!</atidmd:title>!"
    > placemnt="after"><savetext<br/>> textid="wp-bookmarks.txt"
    cleccese1-VisitorAuthor
    Hi Paul,
    Thanks for responding. We are using Arbortext Editor 5.4 M170. I do not know what DIV status is, how do I find that information?
    I went to Help -> About -> PE Configuration and it says
    Adobe Distiller Installed
    Print Engine Default: fosi
    Use Distiller for PDF generation: no
    But when we do File->Print Composed we are sending it to an Adobe PDF print driver.
    Also, this is a large file. If I try to do Compose->PDF, I get a java heap error. PTC pointed me to knowledge base article Document - CS43917 for the java heap error.
    PTC just confirmed that to see bookmarks, you have to do File->Compose->PDF.
    With respect to your DCF (which may or may not need tweaking depending on
    whether Compose PDF solves the problem), elements are defined as div in the
    <elementoptions> tag. A child element of ElementOptions must be declared
    for each element that needs to be a div. It look something like this:
    <elementoptions>
    <elementoption category="division" element="elementnamehere"/">
    <elementoption category="division" element="anotherelementnamehere"/">
    <elementoption category="division" element="etcetcetc"/">
    </elementoptions>
    On Tue, Nov 26, 2013 at 2:13 PM, Caroline Leccese <
    > File->Compose->PDF.
