Feb 22, 2011 12:00 PM UTC
PE Composition Error.
It looks like the stylesheet parameter has not been provided in the composition parameters array: you only specify outputFile please try to specify the stylesheet full path and stylesheet type as well.
That is: the three required parameters to perform batch composition are outputFile, stylesheet, stylesheetType
The first two should be absolute paths, the third should be "style" if using Stylersheets.
    Feb 25, 2011 8:08 AM UTC
    Thanks Marchetti. Stylesheet was missing as parameter to function. Error
    got resolved.
    Thanks & Regards,
    Manisha
    "Marchetti, Alessio" <->
    02/22/2011 04:30 PM
    Please respond to
    To
    cc
    Subject
    [adepters] - RE: PE Composition Error.
    using Stylersheets.
