Feb 9, 2010 11:50 PM UTC
PE Config Question - Lost Stylesheet Selection
A couple of weeks ago, apparently I fixed something that wasn't broken and don't have a clue what I did.
Clicking File | Compose | PDF File, the down arrow next to Stylesheet has gone grey on me.
I can no longer choose from half a dozen stylesheets on the PE.
The Config File down arrow still works.
It is there in the Print Composed dialog box and works fine.
Can anyone tell me what I did to make THAT happen? Or, better yet, how to make it give me the ability to select back?
Unfortunately the PE Config.pdf wasn't helpful.
John T. Jarrett
BAE Systems | Arbortext version 5.4 | LOGSA XSL-FO v 1.5
    Feb 9, 2010 11:57 PM UTC
    Sounds like you made a stylesheet association in the file for printing. That's Format | Select Stylesheets... and then in the dialog you didn't just pick one to use, but associated that stylesheet for printing.
    HTH,
    Steve Thompson
    +1(316)977-0515
    Feb 10, 2010 12:28 AM UTC
    this option is set in the dcf file. it is an attribute at the top,
    something about allowstylesheet selection,. this one bit me last year
    - it seems composer doesn't read this but PE does. I couldn't figure
    out why one I could select and the other I couldn't.
    ..dan
    Feb 10, 2010 12:32 AM UTC
    DCF file?
    <options ...=" allowcomposestylesheetlist="yes" ...<br="/>
    Feb 10, 2010 12:38 AM UTC
    is boeing hiring?
    _____
    Feb 10, 2010 4:43 AM UTC
    I'll give you a job myself if you just stop spamming the list!!
    Feb 10, 2010 1:09 PM UTC
    I was told by someone who checked his profile on ptcuser.org that this guy is a recruiter. Not that being a recruiter excuses the inept email practices.
    Feb 10, 2010 5:28 PM UTC
    Awesome. Yep, someone had uploaded a new dcf file and allowComposeStylesheetList="no" was right at the top!
    Thanks!
    John T. Jarrett CDT
    Tech Writer II, Tech Pubs, ILS, Land & Armaments/Global Tactical Systems
    T 832.673.2147 ext 1147 | M 512.736.7031 | -<">mailto:->
    BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
    www.baesystems.com
