PE/Local composer performance with large PDFs
Hello all,
I'm using Editor and PE 5.4 M100, and I'm having difficulty publishing a large doc to PDF.
Ok, so the document itself is XML, ATA-style markup, and uses FOSI. It's roughly 2.2MB in size, contains references to about 200 bi-level TIFF graphic ents, and also contains several hundred instances of ID/IDREF pairs.
By turning off graphic display and gentext, I was able to get the document to load pretty quickly into the Editor (about 15 seconds). No completeness errors or anything.
Either sending this to PE or by using the local Print Composer (using distiller for PDF), I cannot get this document to render. I had my maxBusyInterval set to 30 minutes, and it considered the subprocess for this composition hung and restarted it. Other than that, I can get no indication of errors or issues that I can address. My PC for local composition is XP, with a dual-core Intel and 3Gb RAM.
The development server I'm using for PE has 4 quad-core CPUs and 48Gb of RAM.
Anyone have any ideas? I tried searching the adepters a few times, but for some reason the filtering isn't working on the site (selecting just Adepters for searching pulls in results for Windchill, ProE, ect).
-Jason
    Hi there name-bruthah,
    Divide and conquer.
    If you can, try the first half of the doc separately and see if you get
    the error. If yes, divide again until you can isolate the specific
    graphic or piece of data triggering the problem.
    Jason
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
    18-Opal
    October 31, 2012
    Hi Jason--
    Here are some troubleshooting ideas off the top of my head:
    When you try to publish locally, what happens when it fails? Does Editor
    crash? Does it give an error in the log window? Do you end up killing
    the process after some long length of time assuming it's hung?
    Have you tried setting the maxbusyinterval higher on PE and republishing
    there? I've seen cases of large documents that require longer than 30
    mins to publish, but once you bump up the limit to avoid timeouts they
    eventually get there.
    Have you tried removing/commenting different portions of the document to
    see if there's something specific in the content that is causing the
    trouble, e.g. a corrupted image file or an unusual XML structure that
    triggers something erroneous in the stylesheet?
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Jason:
    Can you try to publish directly from the server using PE Interactive? If so,
    monitor the process activity via Task Manager to see which process is hanging
    (editor.exe, pubtex.exe, pubview.exe, et al.). If you can, turn on full logging
    in PE, run the job, and inspect the PE logs in the Apache Tomcat directory to
    see how the job was handled. You may find some clues buried in the intermediate
    files which PE normally deletes once the job completes. Examine the javavmmemory
    setting and bump it up if it's low. We set the heap size to 900K before java
    started crapping out; you may have more luck with your larger physical memory
    pool. If you have an Acrobat distiller available on your server, try Print
    Composed... -> PDF from PE Interactive (make sure Adobe PDF is set as your
    default printer first!). We're running XML files in the 60 - 80 MB range (plus
    loads of CGM graphics) without issues on our PE 5.4 M140 Windows 2008 R2 server.
    John
    Jason,
    It sounds like your subprocesses are simply shutting down due to time. I say this since I've got one document that takes about 32 HOURS to publish. It's an index that uses psuedo tables that are built on the fly.
    Anyway, what I would do is turn up your time on PE's configuraiton to a couple of hours. If you still get the indication that your subprocess just died, double the time until you get a finished document.
    As for the server and your CPU/RAM status, if it's not running on a 64-bit server, the extra RAM is not really being used. If it is a 64-bit server, you should be good there.
    At any rate, give the configuration boost a try and see what happens.
    Hope this Helps,
    Bob
    We have seen examples of this sort of really slow publishing too, particularly when Styler stylesheets are involved (as opposed to native FOSI or native APP). As an additional anecdote, one job we were testing recently peaked at almost 14GB of RAM usage. That was a Styler stylesheet.
    -G
    We've had TIFFs fail PE runs before. Give it a shot without graphics.
    After that (and trying other suggestions) it's time to start halving the
    document and seeing what happens.
    18-Opal
    November 1, 2012
    Hi Bob--
    Wow! 32 hours? I think that's a record of some kind.
    --C
    Clay Helberg
    Senior Consultant
    TerraXML
    Another thing that has worked for me using Print Composer in the past is to run Print Preview. This is much, much faster than making PDF because I think it is the creating of PostScript for sending to Distiller that takes up the most time in Print Composer. When print/PDF jobs fail, often Print Preview will produce a DVI file that is viewable right up to the page where the problem occurs.
    Another thing to try is, if you use the filename method for referencing illustrations and use an APTGRPATH environment variable, just set this variable to some local path where there are no graphics. This will speed up your processing, since no graphics will be found.
    This following is information I used to provide my military customers with really big documents. Also, per the PE documentation, set the maxBusyInterval to 0 if you don't want any timeouts, or because you seem to have a general idea, set it to like 48 hours. Hope this helps!
    Susan Fort
    Susan Fort
    Product Manager, SLM Segment
    T 937.743.9091 F 781.707.0602
    E -
    Variable settings that can reduce the time to open very large documents in Arbortext Editor:
    set gentext=off
    set gentextautoupdate=none
    set gentextwarnings=3
    set tabletags=on
    set tabletagdisplay=none
    set graphicdisplay=off
    set tagdisplay=off
    set equationdisplay=off
    set bitmapdisplay=off
    set fosiwarning=on
    set inlineediting=off
    set showentities=none
    Passing data to PE in chunks
    set the environment variable APTPEHTTPMODE to a value of CSM.
    CSM is much smaller and can be set by APTPECHUNKSIZE
    FLSM is also an option, but the fixed length is 4gig.
    Here are the methods for increasing available virtual memory:
    ______________________
    Setting bigjobthreshold:
    1. See this section in the help for details of the 'bigjobthreshold" option: http://www.ptc.com/ae53M30_hc/index.jspx?id=ID552467643&action=show
    At the Arbortext Editor command line, enter the command "eval doc_estimate_dfs(); "
    Then take the number that is shown in the panel that pops up and use it for the value for the "bigjobthreshold" set option. ie: set bigjobthreshold="n" where "n" is the number that appeared in the "eval" panel after the first command.
    For example, after entering the command
    a panel popped up with the number 352 in it. Now set "bigjobthreshold" option accordingly:
    set bigjobthreshold=352
    Set this on both the Arbortext Editor / Styler client machine and the Arbortext Publishing Engine server (in an .acl file placed in CUSTOMPATH/init).
    Setting javavmmemory:
    On both the Arbortext Publishing Engine server and the client machine place the following lines in an ACL file in the ...\custom\init directory of the install tree,
    if (!java_init(0)) {
    set javavmmemory=764
    set javavmargs="-Xss2m"
    Setting 3GB parameter:
    When composing very large documents to PDF on Windows, the
    composition process may fail with an "Out of virtual memory space"
    error message. This situation can occur when the composition process encounters
    a Windows 2GB memory addressing limitation. After installing this release,
    enable this fix by performing the following steps.
    CAUTION
    Ensure that you make the following change exactly as described. Incorrectly
    modifying system files can leave your workstation in an unstable state.
    The following steps update the contents of the file c:\boot.ini using the
    instructions provided on Microsoft’s web site at:
    http:/­/­www.­microsoft.­com/­whdc/­system/­platform/­server/­PAE/­PAEmem.­mspx
    Review the contents of that web page before making these changes.
    1. Stop Arbortext Editor and Arbortext Publishing Engine.
    2. From Windows Explorer, locate the file c:\boot.ini.
    If you do not see the file boot.ini in c:\, ensure that system and hidden
    files are visible using the following steps:
    a. With Windows Explorer open, choose Tools->Folder Options.
    b. Select the View tab.
    c. In Advanced Settings, select Show hidden files and folders.
    d. In Advanced Settings, remove the check mark from Hide protected
    operating system files (Recommended). Answer Yes when you are
    prompted whether you are sure you want to display these files.
    e. Select OK to close the Folder Options dialog box. boot.ini should be
    visible after the contents of c:\ are refreshed.
    3. By default, boot.ini is set to be read-only. To allow changes to the file,
    right-click on the file name and choose Properties. Uncheck Read-only
    and select OK.
    4. Open the file c:\boot.ini in an ASCII editor such as Notepad and add
    the /3GB parameter as described on Microsoft’s web site. The contents of
    your updated boot.ini file will be similar to the following example:
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(2)\WINNT
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(2)\WINNT="????" /3GB
    "????" in the example can be the programmatic name of any of the following
    operating system versions:
    Windows XP Professional
    Windows Server 2003
    Windows Server 2003, Enterprise Edition
    Windows Server 2003, Datacenter Edition
    Windows 2000 Advanced Server
    Windows 2000 Datacenter Server
    Windows NT Server 4.0, Enterprise Edition
    If your boot.ini file lists more than one operating system, ensure that you
    append the /3GB parameter to the operating system you use when running
    Arbortext Editor or the Arbortext Publishing Engine.
    5. Save boot.ini.
    6. Reset boot.ini to be read-only.
    7. Optionally reset the states of Show hidden files and folders and Hide
    protected operating system files (Recommended) in the Folder Options
    dialog box.
    8. Restart your workstation or server.
    9. Restart Arbortext Editor and the Arbortext Publishing Engine.
    Clay,
    The book was an IPB. The tagging for IPB's is such that there are no entries, but rather the individual pieces that eventually make up a row such as <partno>...</partno><desc>...</desc>, etc. So the stylesheet (FOSI) ends up building everything in RAM. The numerical index for our planes is some 1500 pages. Think about it... 1500 pages of psuedo tables... BLAAH!
    Anyway, we don't restart our services over the weekend so these are sent on Friday's. Of course we don't print them often.
    Bob
