PE says "composer 'XSL' not installed on PE server
When I submit the job non interactively. If I choose File > Publish > Using
XSL it works fine.
The compose::compose_for_type() works if peservices=off.
What am I forgetting?
Here's the actual code:
# $myparams["stylesheet"]="C:/custom/doctypes/mytype/createlinkbase.xsl";
$myparams["stylesheet"]="E:/Program Files/PTC/Arbortext
PE/custom/doctypes/mytype/createlinkbase.xsl";
$myparams["outputFile"]= "C:/linkbases/linkbase.xml";;
type = "XSL";
interactive = 0;linkbase_success = compose::compose_for_type(current_doc(),
$type, $interactive, $myparams)
The commented stylesheet line works when peservices=off. The uncommented
stylesheet line fails when peservices=on. The error:
ERROR Error: composer 'XSL' not installed on PE server
Paul Nagai
    18-Opal
    June 26, 2013
    Hi Paul--
    Set type to "xsl" instead of "XSL" and see if that makes a difference. Maybe PE is being moody because it thinks you're shouting at it. 🙂
    --Clay
    naglists1-VisitorAuthor
    I tried that. PE returned a syntax error.
    If I run it peservices=off, I can use "XSL" or "xsl". If I use a "bad"
    stylesheet, it errors (this is peservices=off) and mentions the path to the
    XSL.ccf in Editor's ..composer folder. PE has that file and folder too
    albeit in a slightly different path.
    18-Opal
    June 26, 2013
    Maybe try calling compose::compose_using_xsl(doc, params) instead of compose::compose_for_type()?
    That's what I'm talking about ...
    Thanks, Clay.
