Jun 17, 2011 3:27 PM UTC
PE Server Grahics Formats
I'm running Arbortext Publishing Engine 5.3 M090. I have created an XSL-FO stylesheet. When publishing my document PE Server drops tif graphics. It will process and print CGMs and JPGs but not TIFs. Does anyone know of anytype of configuration setting that needs to be updated to accomplish this?
Thanks in advance.
    Jun 17, 2011 5:52 PM UTC
    Are the TIFs located in a directory that isn't a sub to the manual or doctype directory whereas the CGMs and JPGs are saved locally? We have had several issues with PE losing the path to the graphics and had to work around that.
    John T. Jarrett
    BAE Systems
    Jun 17, 2011 5:56 PM UTC
    I believe that is exactly the issue, the path. I tried using xsl:copy-of to copy the Pub_graphic_data processing instruction but it's not working.
    Here is a sample of my graphic code:
    <fo:external-graphic content-height="{@reprodep" |=" @vscale}&quot;=" content-width="{@reprowid" |=" @hscale}&quot;=">
    <xsl:attribute name="src"><xsl:text>url(</xsl:text><xsl:value-of select="unparsed-entity-uri(@gnbr)"/"><xsl:text>)</xsl:text></xsl:attribute>
    </fo:external-graphic>
    <xsl:copy-of select="following-sibling::processing-instruction('Pub')[contains(.,'graphic_data')][1]"/">
    Jun 17, 2011 8:08 PM UTC
    Other than your "[1]" reference, that looks exactly like what we use as well.
    </xsl:choose>
    <xsl:copy-of select="following-sibling::processing-instruction('Pub')[contains(.,'_graphic_data')]"/">
    </fo:block>
    </xsl:template>
    John
