PEGraphicPI Question
Finally traced down my seemingly intermittent disappearing graphic issue.
Set pegraphicpi=on solves MOST of my problems in lost graphics when composing on the PE.
What I've learned is that it does not set a pi if a graphic is not, well, called a graphic.
Is there any place I can add the other Army 40051 tags to get graphic pi's to be sent to the PE? We have icons, symbols, all sorts of graphics that simply are not called <graphic>. To make things a bit worse, the Army calls the graphic source "boardno" - I guess that makes it simpler because all graphics have that terminology with this DTD, but it is not the same terminology as Arbortext.
This is maddening. If I put all the graphics on the server, I can't reference them with the server's name (\\myserver\graphics) but have to use a drive letter (in this case J:). But to the server, J: isn't really real and gets ignored because the server is run from the main admin account (or something like that). Without the PI, just saying "fire.bmp" means too little and the graphic doesn't get found.
John T. Jarrett
BAE Systems | Arbortext version 5.4 | LOGSA XSL-FO v 1.7
    18-Opal
    April 23, 2010
    Hi John-
    You are using XSL-FO, correct? In that case, it may be that your XSL
    stylesheet is not copying the _graphic_data PI's into the output FO
    instance. So, if you've added code in your XSL stylesheet to copy that
    PI over for <graphic>, but not for all the other graphic-type elements,
    you just need to make sure that you update the stylesheet to copy over
    the PI any time there's a graphic-type element (even if it's not called
    "graphic").
    --Clay
    Oh that's right! Forgot about the code you sent me. *bangs head on desk* Good thing I just got a new leatherette wrist wrest.
    John T. Jarrett CDT
    Sr. Tech Writer, Tech Pubs, ILS, Land & Armaments/Global Tactical Systems
    T 832.673.2147 | ext 1147 | -<">mailto:->
    BAE Systems, 5000 I-10 West, Sealy, Texas USA 77474
    www.baesystems.com
    For history's sake, LOGSA had implemented the code you (Clay) sent me a few months ago for the graphic tag:
    <xsl:copy-of select="following-sibling:Smiley Tonguerocessing-instruction('Pub')[contains(.,'_graphic_data')]"/">
    We use WMFs, by the way.
    I added this line before the close-template tag for icon-set, symbol, and inline graphic, and now they show up.
    Of course, when doing a Compose | PDF File, I still get no graphics AT ALL, but that's obviously a different issue. Print Composed to a PDF driver works just fine...but not the PE's internal PDF driver.
    Thanks!
    John T. Jarrett CDT
    www.baesystems.com
