Apr 8, 2011 8:14 PM UTC
Port used by Arbortext?
I know this is a bit of a goofy question, but does anyone know what port
number is in use when Arbortext reads or writes files from a regular
(non-HTTP/WebDAV) file system?
Trying some exception testing with Riverbed, and the admin asked me
which specific port is being used when Arbortext does read/write
operations.
-Jason A. Buss
    18-Opal
    Apr 8, 2011 8:27 PM UTC
    Hi Jason--
    I'm not sure, but if you're on a Windows network using standard network
    access, it's probably 445, which is the standard port for Windows SMB
    network communications.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    18-Opal
    Apr 8, 2011 8:32 PM UTC
    If you're using NetBIOS, you might also need 137, 138, and 139.
    Clay Helberg
    Senior Consultant
    TerraXML
    Apr 8, 2011 9:04 PM UTC
    Ah, 137, 138, and 139, a fine trio of rapscallions. Reminds me of
    ShieldsUp!! New laptop. Not running ZoneAlarm. Just set up a house to house
    offsite backup for my parents. I'm going to go get a port scan 😉
