possible to double click to select word in AT?
I have to click and drag to select a word, previous version of arbortext would let you doubleclick to select a word.
Is this perhaps a hidden preference setting?Any ideas? (we are version 5.3)
    I don't have 5.3, but in 5.4 double-clicking a word does indeed select it.
    This happens because the default keymap maps "Double+M1" to
    "LeftDoubleClick", an alias for the non-documented function mouse_link():
    # this used to do execute(link mouse) - I removed that to
    # fix bug 20184
    link mouse
    if ($status)
    # The usual fall back is to select the word, but if we're in an
    # empty cell, that would select the cell tag markup which is not
    # expected, so we'll simply do nothing for that case.
    if (oid_is_empty_table_cell() != h::tblNullToid)
    return;
    mark_word(1,1,0); # if link fails, then start marking words
    Obviously word selection happens only if the "link" command fails
    (i.e. the predefined variable "status" is non-zero). Maybe your document type
    implements some link logic?
    / K J
    palsop1-VisitorAuthor
    You are definately onto something,
    I tested your theory aboutit being disabled and found thatit does NOT work in a dita xml file, but DOES work in a j2008 sgml file.
    Thanks.
    We are using DITAXML with 5.4 and double clicking a word selectsthat word. This might be a version issue.
    So it ends up being a bug in our content managment system for both versions 5.3 and 5.4.
    Something in the codeisoverriding the default behaviour.
