Sep 13, 2010 6:33 PM UTC
Print Fosi Question
Good Afternoon,
I have been working with the Arbortext editor for a while
and only use Screen Fosi's because we use SDL's XPP for our outputs. My
question is "When you are using a Screen Fosi do you have to have
Composer for to display your output"?
C. Scott Turner
( (757)896-5505 (work) | * -
    Sep 13, 2010 7:46 PM UTC
    > Good Afternoon,
    What do you mean by output? You can always print the editor view
    with/without tags. Any formatting on the screen is what will print. If you
    mean a final presentation then you are out of luck. You have to have Print
    Composer or PE to get a final document - this is the equivalent of XPP.
    BTW, which NGC are you at? I'm located in Rancho Bernardo.
    ..dan
    > Thanks,
    > C. Scott Turner
    Sep 13, 2010 9:30 PM UTC
    Not required. There is no output for a screen FOSI other than what you see
    in the editor window.
    -Andy
    \ / Andy Esslinger LM Aero Tech Order Data
    _____-/\-_____ (817) 279-0442 1 Lockheed Blvd MZ 4285
    \_\/_/ (817) 777-3047 Fort Worth, TX 76108
    Sep 15, 2010 3:54 PM UTC
    Scott,
    If you want to use the FOSI for a printed output (PDF or paper) you need a print license. I believe that Architect has a license, but last time I used Architect was when I was training you. Smiley Very Happy
    Andy is pretty close to right in that the 'screen' FOSI may not give you everything you want. If you do not have the page sets in your FOSI, then your pages will look pretty rough. Typically the screen FOSIs do not have this and if your still using the one I wrote back when I can tell you it doesn't.
    Lynn
    ---- "Turner wrote:
    > Good Afternoon,
    > Thanks,
    > C. Scott Turner
    > -----End Original Message-----
