Problem Composing Graphics in Arbortext Editor
Hello all,
I'm a newbie to this and need some help. I have a large XML file with several graphics in it - when I open it in Arbortext Editor, the graphics display just fine. When I go to compose it to a PDF, the graphics won't publish...I get a finished PDF with all text and no graphics. Is there a setting I'm missing somewhere?
    Are you getting any warning during the composing?
    Any errors during the validation (Tools -> Check Completeness)?
    Have you authored the XML in Editor or it was authored by someone else / in another tool?
    Is it a Docbook document or a custom DTD-based document?
    What stylesheet are you using for composing?
    Can you share the document?
