Problem with cgms in Arbortext
we have a problem with cgms in Arbortext. We make the drawings with CATIA and then save them to cgm. In Arbortext the drawings look fine and in the preview as well. Nevertheless, when we convert the preview into a PDF, some cgms have funny fines all over them. If we have a look on these drawings in PowerPoint, some other funny lines are shown, but with other programs the cgms look fine.
Any ideas to how we can resolve our problem?
Thanks in advance!
Monica
Are you on 5.4 or 6.0 series of Arbortext? They changed from Larson CGM renderer to IsoDraw (IsoView) renderer in 6.0.
We're still on the 5.3 series
It might be best to convert your CGMs to another format prior to publishing. We have used EPS and PDF successfully in the past. Support for CGM across different software packages is a bit flaky.
