Dec 22, 2014 11:11 AM UTC
Problème ArborText_editor V.6
Bonjour,
Suite à un passage de Epic Version 4.3 --> ArborText version 6.0
Nous rencontrons un problème avec des fichiers contenant des fragments (appel entitée de fichier) en sgml, perte de '<?Pub CX...>' après sauvegarde du fichier englobant.
Y-a-t-il une solution à ce problème pour conserver le contexte ?
Tétière premier fichier :
<!-- Fragment document type declaration subset:
ArborText, Inc., 1988-2011, v.4002
<!DOCTYPE CODE PUBLIC "-//...//DTD ....//FR" [
<!ENTITY chap2 SYSTEM ".....">
texte...... &chap2; ............texte...
Tétière deuxième fichier (chap2) :
<!DOCTYPE CODE PUBLIC "-//...//DTD ....//FR">
<?Pub CX code(...(...(>
Merci de votre aide
    Feb 5, 2015 12:59 PM UTC
    Translation ( Even if my english is not that good )
    Migrating from Epic v4.3 to AE 6.0
    We encounter a problem when referencing file entities : some PI like '<?Pub CX...>' are being deleted in the subfile when saving the main.
    Is there any workaround ?
    Main file :
    Entity file (chap2) :
    Thanks for any help
    My point :
    Does changing writepi to all change anything ?
    Regards
    Dec 22, 2014 4:53 PM UTC
    Have you reviewed the Arbortext Help topics "Context processing instruction" and "APTFRAGCX — Ignoring the context string during e-i-c matching"?
    Dec 23, 2014 3:58 PM UTC
    I did test and that doesn't work!
    Jan 23, 2015 1:37 PM UTC
    Hi Mickael. Are you still experiencing this issue? If so, could you clarify it a bit in English if possible? You'll find more of your fellow contributors may be able to assist with the proper information. Thanks!
