3-Newcomer
Aug 7, 2023 8:50 PM UTC
PTC Arbortext Advanced Print Publisher
I cannot open PTC Arbortext Advanced Print Publisher. License problem: The desired vendor daemon is down Requesting ArbotextAPPDesktop 7788@localhost: (-97)
I had this problem in 2016 and the PTC community solved it for me.
Imtools.exe
Start / Stop / Reread
Stop server
Start server
Server start successful
Now I have the same problem
But using the same solution does not now solve it.
Can anybody out there help me please?
Aug 8, 2023 12:30 PM UTC
Take a look this article - "Error message "License request failed for feature XXX: -97, The desired vendor daemon is down" is returned when trying to launch Application based on Flexlm/Flexnet license": https://www.ptc.com/en/support/article/CS26888
bfriesen
18-Opal
Aug 9, 2023 12:44 PM UTC
Did you update your license file? We have found in the past that you need to also update the license server when updating the license file.
Bryon
jpotter3-NewcomerAuthor
3-Newcomer
Aug 14, 2023 7:15 AM UTC
Hi Bryon
Please excuse my ignorance but would I update my license file and license server through lmtools.exe ?
Best wishes
John Potter
Director & Editor-in-chief
European Rail Timetable Limited
www.europeanrailtimetable.eu
Available to pre-order: Autumn 2023 printed edition, Four Seasons Bundle from Autumn. Available to order: August 2023 digital edition, Summer 2023 digital edition, Summer 2023 printed edition, Four Seasons Bundle, Rail Map Europe 3rd edition, 2nd revision and Europe by Rail 17th edition.
bfriesen
18-Opal
Aug 14, 2023 12:45 PM UTC
The only time you need to update your license file is if you are updating to a new major version of the software, like 7.X to 8.X.
Licenses need to generated from the ptc site. If you log into your support account there is a box that says popular tasks. Choose Manage licenses, this will allow you to generate a new license file.
Then you load the new license file with the lmtools. This is where the lmtools needs to updated to a newer version, so that it will read the new license file properly.
You can always put in a support ticket also https://www.ptc.com/en/support
Bryon
